Moser 9 inch vs. Moser 12 bolt
Not only the pinion support inside the 9" makes it stronger but alot of people fail to mention that the 12 bolts still use pressed in axle tubes instead of the 9" which is a 1 piece construction which is always stronger, for the little bit of power loss the 9" is a better choice 99% of the time for any aplication
I know yal are talking about it being a drag car, im just trying to make mine a fast street car. Not to much on the track. Which would be better for a street car not a track car, 9 or 12"? thanks as well as 4 10 gears or 4 55
