Project Fab 9 begins.....
Guys, I had a body guy come over and do the paint. The epoxy primer is a very durable primer, and to save me time from final sanding the the next stage of primer and base coat, we skipped both and did a color/clear combo called single stage. Expensive, but saves me time in prep. it's done and is a very durable finish. Better than the base coat/clear coat stage.
The project is nearing completion. Just have to bleed the brakes and clean it up. Fired it up on Saturday for the first time in 8 months. Worked through all the issues you always will have with aftermarket parts. You would be amazed how different it is with a narrowed rear end.
![](https://i126.photobucket.com/albums/p92/Brian2001SS/7c217df6.jpg)
![](https://i126.photobucket.com/albums/p92/Brian2001SS/4c162d47.jpg)
![](https://i126.photobucket.com/albums/p92/Brian2001SS/1eb64af2.jpg)
![](https://i126.photobucket.com/albums/p92/Brian2001SS/cdc2bf4b.jpg)
![](https://i126.photobucket.com/albums/p92/Brian2001SS/90bae890.jpg)
![](https://i126.photobucket.com/albums/p92/Brian2001SS/817736ca.jpg)
![](https://i126.photobucket.com/albums/p92/Brian2001SS/54b0a254.jpg)
![](https://i126.photobucket.com/albums/p92/Brian2001SS/187ecfab.jpg)
