Cheapest 9"
Old Oct 6, 2011 | 02:20 AM
shepss217's Avatar
Default Cheapest 9"
Whats the best price i can get on a 9" rear housing with all the correct brackets to use my suspension and factory brakes with the addition of the drain and fill plugs? Also can i use my edelbrock non adjustable torque arm or do i need to buy an adjustable piece? In case someone asks its for an 02 z28 with mods listed
Old Oct 7, 2011 | 05:16 PM
93v8clone's Avatar
Quick performance , but your gonna need adj lowers and panhard
Old Oct 7, 2011 | 06:09 PM
garygnu's Avatar
check out brute speed or look for a used 9"1 in the used parts sections.
Old Oct 7, 2011 | 06:14 PM
TransWS6Am's Avatar
Quick performance also gets my vote for cheapest 9"
Old Oct 7, 2011 | 07:17 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Thanks, here is a link to just the Moser housing.
http://shop.brutespeed.com/Moser-9-I...ch-Housing.htm Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Oct 7, 2011 | 09:35 PM
Valkyn's Avatar
For the cheapest 9" buying a housing and axle package then get a used center section off yellowbullet or somewhere.
They are very common and its not hard to find a used setup with the gear ration you want already setup.
Old Oct 11, 2011 | 06:39 AM
WVws6's Avatar
Bob, with this housing, what is left to purchase for a direct bolt on to the car?
Old Oct 11, 2011 | 06:47 AM
LS1Tech Sponsor
The best way to go with with the housing and axle package, shown here.
http://shop.brutespeed.com/Moser-9-I...-and-Axles.htm
With the above combination all you will need is a center section. Old Ford pick up trucks and some of the larger Ford cars came with 9 inch rears. Let me know if you have any questions. Thanks. Bob
__________________
Old Oct 11, 2011 | 08:39 AM
shepss217's Avatar
ok, i have the panhard, will my torque arm work being a non adjustable one?
Old Oct 11, 2011 | 09:08 AM
LS1Tech Sponsor
Yes it will, not a problem. Bob
__________________
Old Oct 11, 2011 | 12:13 PM
MidwestChassis's Avatar
LS1Tech Premium Sponsor
Cheapest can some times be an ugly word to use because with a cheap price can some times mean cheap quality when it comes to fit and finish plus needed items for installation to make that process go smoother when installing the rear end.
With that being said we can get you into a housing and axle package with one of our fabricated nine inch rear ends for $1650 shipped to the lower 48 states. This package includes housing(any width),31-35 spline Strange axles w/ street bearings and 2" 12mm metric or 1/2" SAE studs, chrome-moly double adjustable torque arm with crossmember for your application. All necessary hardware is included as well.
Rearend housing features components such as a drain plug, 4 hole relocator style lca brackets(any style of stock mounting LCA will bolt into place), PHB bracket(stock style mounting PHB will bolt up),stock style anti-sway bar mounts, brake line clips, chassis brake hose mounting bracket, brake hose mounts and e-brake cable brackets(98-02) all as standard equipment at no extra charge. A fill cap is $30 but most cases have a fill/site hole that can be used as well.
The chrome-moly double adjustable torque arm is included with the package and is exclusive to this housing. Short (tunnel mounted) and long (trans crossmember mounted) versions available. Both are the same cost, the short arm crossmembers come with a driveshaft loop installed (available with dual exhaust), the long arm comes with a new trans crossmember, but no loop.
Old Oct 11, 2011 | 01:19 PM
LS1Tech Sponsor
Thumbs up
As you well know, there is no cheapness to a Moser rear. Bob
__________________
Old Oct 11, 2011 | 01:36 PM
SLP IROC-Z's Avatar
midwest chassis, by far.
Old Oct 11, 2011 | 01:37 PM
HoLLo's Avatar
I consider mine was pretty cheap by scoring a good condition 9" center section with a TracLoc on Ebay and going with a Moser 9" housing/axle package. Assembled it myself
Old Oct 18, 2011 | 08:44 PM
shepss217's Avatar
ok awesome, thanks for all the repies, i just bought a used center section out of a bronco everything included for $50, all i need now is the housing and axle package, i plan on putting in a full spool and rebuilding the center with all new bearings
Old Oct 18, 2011 | 08:48 PM
02ws.sik's Avatar
i can give you a guys number for a 9 inch wave trac with 31 or 35 spline with every thing you need shipped and taxes for 2517
Old Oct 18, 2011 | 09:17 PM
westtexasbuff's Avatar
x2 for Quick performance on center sections. Bought a brand new aluminum strange center with spool for 800 shipped.
Old Oct 18, 2011 | 10:42 PM
1badzee's Avatar
Quick performance has some of the cheapest (in price) stuff. I was considering their brand housing+axles package. But BruteSpeed's price on the moser housing+axles is as cheap as you will find it. Lots of good prices here
Old Mar 5, 2012 | 11:18 PM
shepss217's Avatar
went with the quick performance 9" got everything needed to swap out for $1938, that was including me buying a UMI tunnel mounted adjustable torque arm, a new billet steel yoke and a 3.70 motive ring and pinion that i didn't need but wanted the bigger gear
