Can you use umi torque arm for a moser 9 inch?
1 Post
Most times you need an adaptor added to the rear end. You didn't mention which moser rear so I suspect you mean the generic 9" style like this...
![](http://www.spohn.net/productimages/1318/Moser-Engineering-Ford-9-Rear-End-1982-1992-F-Body-Camaro-Firebird-1.jpg)
For this I've seen 2 adaptors like these...
![](http://bdrperf.com/camarosite/images/currie/currie1.jpg)
or
![](http://www.currieenterprises.com/cestore/images/product//currie/ce7009.jpg)
If you change out the brackets you could use this...
![](http://s3.racingjunk.com/ui/1/61/13704611-355-9quot-Ford-Bolt-In-Housing-8202-Camar.jpg)
Now if you're talking about the fab style rear end, the above is useful if the idea of 800 or so for the torque arm doesn't thrill you...
or
LS1Tech Sponsor
I've had customers use their UMI torque arms with the Moser 9 inch with the torque arm mount that comes with the Moser rear. It is best to fit it before installing the rear into the car. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
LS1Tech Sponsor
__________________
I have the Moser 9 inch & UMI torque arm setup & it was not a "bolt it in & go" install. the torque arm bracket that mounts to the bracket on the rear will require a little cutting & grinding. if i remember correctly, i also had to do a little grinding on the rearend bracket also. if you opt for the driveshaft loop with the torque arm, make sure you have adequate clearance especially if using a driveshaft bigger than 3" diameter. i installed the Moser 9 inch, UMI torque arm with driveshaft loop & PST 3.5" driveshaft at the same time & to shorten the height of the driveshaft loop pedestal by approximately 1". luckily, i'm pretty handy with a welder. hope this helps.
It is bolt in and go...if I remember correctly, you have to specify which rear end you have when ordering. I can see the DSL being an issue, it's a tight fit in there. Everything bolted up just fine for mine. Easier way i found was to bolt the Tq arm to the rear and install together.
Well your right there. Seems umi's website is alot more iPhone friendly or i would of checked earlier. Guess it goes with these cars, nothing fits like it's suppose to. But as said, mine went together right.
Hello,
We have installed and used our torque arm on quite a few Moser 9"s over the years with out any issues. If the casting of the Moser 9" varies at all this may cause an issue like Nsty had, but other than that I am not sure why it didn't work correctly. We haven't changed or altered the design of our rear bracket since day one.
Like Bob said, test fit the items out of the to make sure all the items slide together easily. This will make the install 100x's better.
I hope that helps,
Ryan
I hope that helps,
Ryan
