Nine inch install sequence?
Old Nov 23, 2011 | 07:42 PM
Valkyn's Avatar
Default Nine inch install sequence?
Im working on installing my moser 9" and don't know what the proper sequence is for the install. What suspension things need to be connected first and when should the pinion angle be set?
Right now I have the LCAs, PHB and torque arm on but not tight. My driveshaft wont hookup tho, the rear is still too far forward.
At what point should the rear be centered in the wheel wells and side to side? When everything is hooked up and the axle hanging in the air? Is it the same for setting the pinion angle?
Old Nov 23, 2011 | 10:48 PM
Damian's Avatar
LSX Mechanic
I like to get everything hung up finger tight including the TQ arm to get it all in place. Then start tightening stuff down.
The reason you can't put the DS in is because the TQ arm probably isn't bolted up yet. The rear will be centered by the Panhard rod.
Old Nov 23, 2011 | 11:32 PM
Valkyn's Avatar
I have the torque arm in, the front portion on the tranny is tightened already...maybe thats why the rear dosent want to move enough to get the DS in
Old Nov 25, 2011 | 08:41 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I suspect you have the rear hanging down right now, get the rear into the loaded position to install the driveshaft. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Nov 25, 2011 | 08:55 PM
Valkyn's Avatar
I got the driveshaft in after centering the rear in the wheel wells with the LCAs and jacking the axle up all the way until it started lifting the rear of the car. It still didnt have much extra room, I had to fight it in abit but it went.
I measured the rear and it is around 45 inches from u joint to u joint. The stock DS is 44.5" i believe. I've read that the DS for a t56 to moser 9" should be an inch longer than stock, does that sound right?
I also read that if the front suspension is loaded that the DS may be hard to get in, which is how I have the car in the air...anyone know if this is true?
Old Nov 27, 2011 | 08:19 AM
LS1Tech Sponsor
Yes, the driveshaft length for a nine inch should be one inch longer than it is for a 10 bolt or a 12 bolt.
I can't see how the front suspension could effect anything. The engine is mounted to the K Member and the transmission crossmember is bolted to the chassis. Bob
__________________
