Do ratech install kits come with timken bearings?
Here's a link. Check out the product info in the right column. Ratech uses a mix of bearings. I used a Richmond master install kit and it came with Timken bearings for the ring/pinion and carrier with Torrington bearings for the axles, all bearings were made in USA.
http://ratechmfg.com/toc.htm
