Can't believe it!
Old Jan 12, 2012 | 08:45 PM
av8er1555's Avatar
Default Can't believe it!
When i bought my car about one year ago I noticed a semi-loud noise coming from the rear end. I paid little attention to it because one of my buddies said 10 bolts are just noisy... well I bought 4.10s recently and was in the process of disassembling the rear end when I took the carrier out and noticed that the side with the plate with the bearing on it (not sure of the proper name) was completely sheared off! I think I'm pretty lucky it lasted this long. Good thing I ordered the Ratech deluxe kit for all the bearings because they are all shot.
Old Jan 12, 2012 | 09:20 PM
throwed_TA's Avatar
Seen the same thing happen in a buddys car. have no idea how long he drove it like that haha pretty crazy.
Old Jan 12, 2012 | 09:32 PM
av8er1555's Avatar
haha honestly it just sounded like a wheel bearing or something so I wasn't immediately concerned.
Old Jan 13, 2012 | 02:20 PM
av8er1555's Avatar
And also I have another question. I took the end plate and the piece that broke off with the bearing to a GM dealership and they said "thats not a stock differential". Well after doing some reading up on it, I found out that its a Torsen carrier and they only came in the 99 F-bodys. So as for my question, is there anybody who knows if I can only get the end plate? Or do I have to buy a whole carrier?
Old Jan 13, 2012 | 04:38 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
this is the 4th thread,here on ls1tech,I've seen about that end plate failure.
Torsen doesn't supply/sell replacement parts,the most common part needed is the 'paddle' as they're 'lost'.
You can obtain that end plate by picking up a used torsen carrier,they typically sell for 100-150,or a scrap torsen carrier that still has an intact end plate but is scrap due to internal gear failure.
Old Jan 14, 2012 | 10:34 AM
av8er1555's Avatar
Thanks, sorry I should have used the search but I looked on ebay and found a nice used torsen. But thanks for the response!
Old Jan 14, 2012 | 01:01 PM
96lt4c4's Avatar
Never seen that one before.
Old Jan 16, 2012 | 04:09 AM
bww3588's Avatar
The torsen differential was in all 99 up cars except ss and firehawk cars with the optional auburn posi
