Vibration in rear???
My car has a vibration in the driveline.
At first I thought it was the u joints. I swapped driveshafts and it is still there.
The pinion has been leaking for the life of the car.
could it be a bad pinion gear or bearing causing it?
Thanks guys. I have had the tires rebalanced and it still does the same.
When I jack the car up and it is in gear the rear wheels still move some. is that normal?
I guess the feeling that describes it best it that is kinda shudders when I back up, then when I go down the road it is just a constant viibration and you can feel it in the tunnel, but not the steering wheel.
