my Eaton posi unit is slipping now what
So at the track im getting single tire spin on ocassion. Its a Moser 12 bolt Eaton posi. I can put clutches in it but I don't feel like it will last. This thing has almost no miles on it anyway. So I have a twin turbo 6 speed street driven some track duty. What's my best plan. Im not messing with single tire burnout this year.
The carrier you have can be fixed rather easily. You just rebuild it tighter. You can get very tight by adding a shim, I'll explain if you're interested. http://www.ebay.com/itm/Clutch-Pack-...853870&vxp=mtr
The only problem is getting it back together. I used to use a flywheel to crank bolt with a nut as a jack to jack the axle gears apart so the spider gears will go in.
If it's done correctly you will never spin one wheel, and it will push the front end a tad when you get off the highway after a long 70 MPH run. And you won't need to reset the ring and pinion like you will if you swap carriers.
Al 95 Z28
Al 95 Z28
