making a 4 channel rear
Old Feb 6, 2012 | 08:34 AM
BadAm73's Avatar
Question making a 4 channel rear
My question is if you have a 3 channel rear what do you have to do to make it a 4 channel like on a S60 or 12 bolt?
Old Feb 6, 2012 | 08:41 PM
DarkJuggalo's Avatar
axles and backingplates like a 10bolt i assume?
Old Feb 25, 2025 | 01:05 AM
RideZilla33's Avatar
Yes. 10 bolt
Old Feb 25, 2025 | 06:59 AM
JohnnyBs98WS6Rag's Avatar
Need to add tone rings to each axle and the magnetic sensors on the brake backing plates (along w/ the appropriate harness for the 4-ch mag sensors). 3-channel rears will not have the tone rings on the axles (they use a single tone ring on the ring gear), which are needed to send in to the fab shop building your new rear axle. I am not sure if the brake backing plates for a 3-ch rear has the provisions for mounting the mag sensors.
