How do you remove the axle shaft?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I have a 1997 Camaro SS. I broke the axle in half near the hub. I have a replacement axle shaft and have the differential cover off. I don't want to begin unbolting stuff that I don't need to. What needs to be removed in order to get to the c-clips to pull the shaft out?
Also, I have 3:43s. It looks like I have an auburn posi differential.
Thanks
Thanks
I'll shoot from memory here, the last 10 bolt I tore apart was over 10 years ago. On the carrier you will see a bolt running sideways that holds in the pin between the two axle shafts. Remove the bolt, move the pin enough so you can push the axle in so you can access the c clip.
Now this was on a car without any traction control, I'm not sure how that may change things.
like gmdoctor said...youl need to spin the carrier until you see a small bolt, its like a 7mm i believe going sideways, remove that, and theres a big half inch pin, about 5inches ling youll need to remove also, be careful not to spin the carrier too much or your spider gears will fall out and theyre a mother ****** gettin back in place...remove the wheel speed sensor by the wheel if it has this type, push the axle inward, and remove the c clip, then the axle should pop/slide out of the housing, it may appear to be somewhat stuck, but youll havta pry a lil inside the diff aginst the axle to get it to pop through
Well, I got it out! Thanks guys. Now, for question #2)
How do you remove the axle shaft seal? Mine is trashed and rusted in. Do the bearings come out with it?
Thanks,
Spencer
Thanks,
Spencer
