A Strange 12 bolt Install
Old Mar 26, 2012 | 10:40 PM
Kent1's Avatar
Good write up. I order a complete Strange 12 volt rear end in 2008 and no issues whatsoever. I have 4:10 gears and it does not howl and is super quiet. I believe you will really like this package.
Old Jun 2, 2012 | 08:10 PM
01ssreda4's Avatar
Added pics of the upper support bar mod.
Old Jun 5, 2012 | 11:57 PM
Blackbird-WS6's Avatar
nice write up
how much rwhp you think it will take thru a auto??
Old Jun 6, 2012 | 03:12 AM
01ssreda4's Avatar
Dunno, lots I suppose. Autos are easy on drive-train parts.
Old Jun 6, 2012 | 03:28 AM
I'm looking to putting around 600rwhp with a auto...
Sees the track maybe once a month if that, mostly street car
Old Jan 17, 2015 | 08:14 AM
01ssreda4's Avatar
Pic of spool added!
Old Feb 16, 2015 | 01:16 AM
JakeFusion's Avatar
Super Hulk Smash
Did you have to modify the torque arm at all to fit the Strange TA mount? I know it's a common practice on the Moser but this looks similar to stock.
Old Feb 16, 2015 | 05:50 AM
guppymech's Avatar
Here's the install instructions from Strange.
http://www.strangeengineering.net/fi...1386862436.pdf
Old Feb 16, 2015 | 05:52 AM
01ssreda4's Avatar
Nope, no need to!
Old Feb 16, 2015 | 03:22 PM
JakeFusion's Avatar
Super Hulk Smash
I'm really digging the Strange housing.
Old Feb 16, 2015 | 10:11 PM
01ssreda4's Avatar
Me too. It's been solid since day 1, zero complaints..
Old Mar 7, 2015 | 05:16 PM
  #32
onebadapple98's Avatar
I just bought the strange 12 bolt complete rear with 3 channel abs from one of the sponsors here, and was wondering how that Rustoleum paint is holding up on your rear.
Old Mar 7, 2015 | 05:33 PM
  #33
01ssreda4's Avatar
Good, you have to mindful of jackstacks on the axle tubes and stuff but other then that its fine.
Old Mar 13, 2015 | 06:06 PM
  #34
Do you think the new TA performance low profile cover will clear that upper panhard support. They claim it will give 3/4 of a inch more of clearance.
__________________
Old Mar 13, 2015 | 06:46 PM
  #35
01ssreda4's Avatar
I think, itd be close.
Old Apr 5, 2015 | 11:10 PM
  #36
MikeSp's Avatar
Default Strange Rear
Did you order the rear stock length, or 2-3" shorter?
If you ordered it shorter, what reference measurement did you give to Strange? They told me that they wanted the dimension either between axle faces or backing plate faces.
Thanks.
Old Apr 6, 2015 | 06:43 AM
  #37
01ssreda4's Avatar
This one is stock length.
Old Apr 6, 2015 | 08:54 AM
  #38
LS6427's Avatar
I had my Strange 12 bolt installed back in 2002....all the heavy duty upgrades and 33 spline with TCS hookups.
13 years later......100% silent and smooth operator.
I changed one bad bearing in 13 years and one axle seal.
Great rear-ends.....
Old Apr 6, 2015 | 10:40 AM
  #39
Siciliano15's Avatar
I also have the strange 12 bolt but ive only had it for about a year. 3.42 gears. so far so good. didnt feel much heavier than the stock 10bolt but you can tell its much stronger. got it powdercoated so hopefully that lasts a while. torque arm mounted right up. only thing that sucks about it is theres no more side fluid fill so you have to add fluid from the cover and its harder that way because of the angle to get the fluid in there.
Old Apr 6, 2015 | 10:58 AM
  #40
01ssreda4's Avatar
Strange machines the hole up top for the abs sensor whether you need it or not. Remove the sensor or plug and fill from the top if thats easier.
