A Strange 12 bolt Install
Got it pulled and hung up for full disassembly.
And off to the powder coat shop!
Going more low key this go round, went with gloss black.
And that little custom touch that makes it your own and unique.
All that hard work, lets relax by the BBQ grill with some LSX buddies.
Should have it reassembled this week, a few tuning tweaks, and off to the track March 11th weather permitting of course.
Stopped at home depot and got some angle iron and some all thread. After all the rear ends ive built I'm finally building myself a case spreader.
The case has one 3/4 and one 1/2 hole for the case spreader to attach to, so I found some scraps that fit those dimensions. I did have to revise this design as it was blocking the bearing caps from going in. No big deal, we are learning.
Here it is set in place. You turn the buckles and the case spreads. Easy as pie.
And this is why you need a case spreader. I pulled this out during disassembly. No doubt it got bent during final carrier preloading last time when I swapped the spool in.
May not have this out again for a while so I decided to take some weights. This is the empty housing weight.
This is fully dressed weight. It has a spool, no brakes, aluminum rear cover.
I was an idiot to not powder coat this thing sooner. It looks very pimp now. Will reinstall this weekend. Stay tuned.
Thinking about a strange 12 bolt with a spool with 3.90s for my Z. It's an A4 with a 4000 stall.
