Advice on which rear end to go with?
good info. See I didn't know that I had a detroit locker in mind to start with. You first need to decide on a rear. Then decide the necessary stuff for that rear. If you go 9 inch youll need a housing/axles (spline determined by carrier)/decide factory or aftermarket brakes/ABS or no ABS/ type of locker(carrier)/gear ratio/driveshaft
as for me:
QP housing
Moser 31 spline axles sealed roller bearings
Nascar 3rd memeber = 31 spline detroit locker, lightweight 4.11 polished gears, Strange nodular case
Reusing factory brakes
ABS delete (it didnt work with the 10 bolt)
UMI full length TA
Nascar shortened 4 inch driveshaft
and a nice thank you to Lakey Cornelius at RCR
as for me:
QP housing
UMI full length TA
you are right about the 3rd members......
i had a strange aluminum case with spool & 456..... light,broke it.
and a cast strange S case with spool & 456 gears......a little heavier
and now i have a yukon bolt thru case with spool & 456 gears......weighs the most,but what a monster! i dont see ever breaking it.....
I've got the Tru-Trac in my S60, and as long as your follow the directions from Strange (non-synthetic oil with limited slip additive), it will work flawlessly, street or track, and is 100% completely quiet. You would have no idea that the rear wasn't stock unless you looked under the car.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
I have a MWC fab9, 4.11 gears, spool....itd a lot of fun to drive, except on tight turns, lol....if you want something you wont have to worry about braking, get a 9" with a wavetrack, its gonna cost a bit more, but you get piece of mind in return...if you want more info I recommed you call a sponsor that way they can put together a set up that sutes your needs
LS1Tech Premium Sponsor
Give me a call. I can go through all the rearends and options to get you the right parts for your needs and the guaranted best prices. I designed and manufacture the ever-popular MWC fabricated 9 inch rearend package, and MWC is also a direct dealer for Strange(S60 rearend and 9 inch components), Moser, and Yukon gear & Axle. I have the most options of anyone selling rearends and the knowledge/experience to back it all up.
You will get 10 different stories from 10 different people here, which isn't all bad, but I know all of these rearends and can answer any question you have.
#34
LS1Tech Sponsor
http://shop.brutespeed.com/Brute-Spe...nformation.htm
I have a lot of info at the above link that may help you out.
http://shop.brutespeed.com/Moser-12-...structions.htm
Installation instructions can be found at this link.
http://shop.brutespeed.com/82-02-F-B...Ends_c2289.htm
My Moser shipped prices can be found at this link. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
