Bent axle? vid inside
OK, put a 9" in my car. Prior to installation I found the passenger side end housing was wallowed out. Should of measured 3.150, it was at 3.175. Had end housing replaced but never had axles checked. ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
I had these same rims on my ten bolt with no vibrations at all, so I am ruling out bent rim. I followed my wife yesterday to see how the rear looked as far as centering and noticed immediately the passenger tire was wobbling bad. My guess is the axle is bent which is what caused the end housing to be enlarged. Thoughts?
I'll be pulling the axle soon and have it checked.. I've had the balance checked on the tires 3 times this last week, if it was the rim, I am sure they would of noticed it during balancing.
Vid shows drivers side first, then passenger side..
![](http://i100.photobucket.com/albums/m36/OIF1VET/th_MVI_1536.jpg)
