Moser 9" Installed - Initial thoughts....
I also have a Moser 9in with ABS/TCS 4 channel. A word of caution i have a Detroit locker in mine and the Locker and the TCS don't like each other. If i give it gas going around a slow cornor the TCS goes off.
The guy who installed it (I didn't do it myself) had to fab and weld on some stuff to hold the brake lines in place.
Yes, it has TCS and ABS (4 channel).
I found the first thing to gripe about. It leaks; both out the pinion seal and the main seal. I can tell it's a couple drops a day from the stains on the driveway.
. i've gotten used to replacing seals periodically. it's pretty easy. as of right now my rearend dosn't leak a drop
