Fluid???
Old May 23, 2012 | 01:50 AM
lilblackLT1's Avatar
Default Fluid???
i have a 9 inch strange aluminum center section, 4.10 gear with a detroit locker my ? is what fluid do you guys recommend do you use synthetic, posi additive,
or just some regular old petroleum gear lube...it's a street car with occasional track beatings
Old May 23, 2012 | 04:52 PM
Exeodus's Avatar
I use Lucas Gear Oil with GM Posi additive in my S60. That is what Strange recommended and strictly forbid using synthetics. Since a locker is not a really a posi unit, you may not need the Posi additive.
Old May 23, 2012 | 05:28 PM
Carl at CRP's Avatar
A quality petroleum/mineral based oil works best in the Detroit Locker units. Do not use synthetic oil. Friction additive/modifier is not required.
Carl
Old May 23, 2012 | 05:30 PM
Which posi unit is in Your S60? If it is the Truetrac or the S Trac no posi additive is required.
Carl
