Removing Diff.. screw up lash?
I need to know If I pull my Diff if it will mess up any spacing or lash...
I just need to flip it 180* and put it back in.
Thanks guys!!
Absolutely WRONG the back lash is set with those spacers. If necessary remove the caps and slide the carrier to the rear so you can release the stuck pin. Then replace th caps and dont mix them up or install them backwards. The porch of the caps face outward. I always mark the sides of the caps with a Dremmel or center punch to identify their location.
DO NOT TRANSPOSE THOSE SHIMS!!!
