beating a dead horse
You can see the mods in my signature. I am wondering if the 10 bolt will last? I know it is a weak rear and that the 6-speed guys just do a few good dumps or less and snap them all day. To my knowledge this is caused by the shock to the rear housing. I have not seen a lot of people braking the ring or pinion gears. I know that also installing the "T/A" diff covers will give them a little more life. The auto cars seem to have better luck with the rear ends lasting. I think this is cause the torque converter uses tranny fluid and there is less shock running through out the drive train.
With my car, like most autos, the tranny went out so I had it rebuilt "stronger". I also put in a 9.5" vig.3000-3200 single disk lock up converter with an anti-ballooning plate. By running the bigger stall is this going to be "softer" on the rear axle than a stock converter? My horsepower goal is about 450-500 on the bottle and being that the car is my daily driver for now I don't want to do more than that for a long time. All that information had lead up to this. The diff has gone out in my axle. I now can only do peg leg burnouts and from a slower rolls like 20-25 range if some one wants to race me I spin the passenger side tire only. Being that I have a lower HP goal and I have a "bigger stall"
is it worth spending the money to get a better diff put in the 10 bolt or do I need to just get a 12 bolt/9" that is bigger? Money is kinda a factor cause I am young and don't make TONS of cash. Plus with the bigger rear ends I know there is more parasitic loss cause they have more weight and friction. That is a factor for me cause I don't plan on making "huge power".
WHAT DO I DO??????
Most will probably say to buy a 9in, but with your mods, unless you're planning on a lot of track time, I'd say you would probably be better off just buying a spare 10 bolt just in case. When you add up the money, you'd have to break quite a few of them before you'd spend the amount of money that you would on a MWC 9in or similar.
The cover isn't a miracle worker but with the 7.5 every little bit helps.
That is what I kinda did...but I have four vehicles.
