Slicks on stock diff
Old Jul 4, 2012 | 11:46 PM
dannyz's Avatar
Originally Posted by why87
With the few mods you have, why risk it? Especially if you have 2.73 gears....If you had a stall I'd see a good reason to run a sticky tire. Just use a street tire. You may not be able to run slicks with the stock c-clipped axles anyways. Depends on the track.
Risk what?
The fewer the mod's, the less power to the gears, so even less risk, right?
Especially with 2.73 gears???
That is the strongest gearset you can get for the 10bolt.
This post makes zero sense.
Old Jul 4, 2012 | 11:55 PM
dannyz's Avatar
Originally Posted by Dan
Ran ET Streets, ET Drag Radials for 11 years, Dead hooking with 60's in the range from 1.56 - 1.79's with an Auburn Posi & 3.42's,(Auto Trans) No other upgrades to it. It finally broke a month ago. I don't know how many passes I had on it, I would estimate 300-400+.
This has been my experience.
Have been running ET/DR's for years with 60's in the 1.53-1.70's on a BONE STOCK 10 bolt.
No issues.
This year switched to a bias ply to get a more consistant launch.
I was surprised to find that not only did my 60' time drop, but that a 1.46 short time on the bias ply was not as violent as the 1.53 that the DR's gave me. The bias ply did a much better job of absorbing the shock of the initial hit.
Old Jul 7, 2012 | 05:35 PM
SS SLP2's Avatar
Originally Posted by therabidweasel
You can run slicks on a 10 bolt, you can drive a car with your feet, and you can light a fart with a cattle prod, but i don't recommend any of those things.
^ I'm with U
Johnny
Old Jul 7, 2012 | 07:35 PM
BlueBird346's Avatar
Ive made 15 passes on a set of Hoosier QTPs. 6 speed, bolt ons, stock rear. 1.7 60' times. I launch from 5k, slip the clutch, not dumping it. Never had a problem. I think as long as you dont dump the clutch and have stock gears you should be fine.
