Moser M9 vent?
Old Jul 19, 2012 | 07:22 PM
6togo's Avatar
Default Moser M9 vent?
I have a M9 housing and it has a hole tapped for a vent and a barbed fitting came with it but i'm not crazy about the look of that and a rubber hose anyone come up with something that looked better?
Old Jul 19, 2012 | 09:33 PM
XtraCajunCTS-V's Avatar
Its easy to find an NPT to AN adaptor and run a stainless steel braided line.
Shane
Old Jul 19, 2012 | 09:40 PM
onfire's Avatar
Coal Mining Director
Ran a 90 degree instead of the one supplied and ran a rubber hose up through the cross support over the diff,,,,,everyone will ask...where does that hose go?
Old Jul 19, 2012 | 10:40 PM
6togo's Avatar
What goes on the other end if i were to go braided?
Old Jul 20, 2012 | 06:43 PM
Pocket's Avatar
Nothing, its a vent
If the supplied barb clears, whats it matter what it looks like? Do people routinely inspect your rearend?
Old Jul 20, 2012 | 11:12 PM
6togo's Avatar
This is a show and go build so i care what it looks like and there is no plain rubber hoses on this car! and i surely will not leave the end wide open even stock vents have some sort of breather tip inserted in the hose just looking for something decent looking.
Old Jul 21, 2012 | 11:13 AM
onfire's Avatar
Make sure whatever you do, you keep an open vent or you will start pushing fluid past the wheel bearings.
Old Jul 21, 2012 | 03:07 PM
6togo's Avatar
I need to find some sort of AN vent to go into the SS line instead of leaving a raw end open anyone seen something like that?
Old Jul 21, 2012 | 03:48 PM
onfire's Avatar
Get crazy and put a K&N valve cover vent on the an line.
Old Jul 21, 2012 | 07:00 PM
LS1-IROC's Avatar
I use sintered bronze filters. They look good and can be had with NPT or AN straight threads.
Old Jul 21, 2012 | 09:13 PM
onfire's Avatar
Has to be bigger than the dime sized SI or it will not flow enough to keep the rear from pressurizing.
Old Jul 23, 2012 | 06:07 AM
LS1-IROC's Avatar
Works fine for me....the filters can be had in different configurations that allow alot more surface area than what you are thinking.
Old Jul 23, 2012 | 07:36 AM
6togo's Avatar
I found so threaded polished vents from Summit i think they will do the trick!
http://www.summitracing.com/parts/SUM-E730301/
Old Jul 23, 2012 | 12:54 PM
onfire's Avatar
The one we tried was a tight mesh bronze. Wound up drilling a 1/8" hole in it to get enough airflow to keep the pressure down. I'm sure they make different styles with different void ratios that should work.
Old Jul 31, 2012 | 05:18 PM
LiT1_up's Avatar
I used the stock one out of the 10 bolt.
