Fed up with 9" vibrations
Old Aug 18, 2012 | 10:45 AM
OldCobraGuy's Avatar
I have to agree with 96lt4c4. I had a set of wheels that had the wrong size center and used the lugs to center the wheel. I never did get rid of the horrible vibration. Installed a set of hub centric rings and cured it. But having rings machined is not a cheap endeavor. Get the right wheels the first time. I decided not to buy the rings and went with new wheels instead.
Old Mar 7, 2013 | 08:48 PM
shepss217's Avatar
hmm this is all new to me, i have racestar industries drag wheels and i have a vibration, and i know the lugs center the wheel but i also had a vibration when i was running the stock chrome slp wheels so i'm thinking it could be something else
Old Apr 12, 2015 | 09:51 AM
codyvette's Avatar
I know this is an old thread but I am having the same issue with my Firehawk. Moser says the lugnuts should center the wheel. I am sure this works a good portion of the time but it isn't working for me. Moser is all knowing and they are pretty much no help. I removed my brake rotors and bolted my racestars right to the axles so the the hub centers the wheel and they run straight and true. From what I have read Strange is the same way. Has anyone welded up there hubs and cut them to the proper diameter?
Old Apr 12, 2015 | 10:55 AM
_JB_'s Avatar
I ended up getting a custom set of hub adapters from http://motorsport-tech.com/. After I added the adapters the rims now run true (stock rims), and 80% of the vibrations are gone (the rest I attribute to a solid MWC rear setup). It wasn't cheap, as I paid $125 for the adapters.
Here's what I ordered, but if you go this route, you MUST measure your hub as they are probably all different in size: 2 Hub & Wheel Centric 3mm Thick, 5x4.75 68.91 to 70.51 (.620"Tall).
The .620 tall measurement was to extend the hub flange into the rim. The stock axle hub is .5" into the rim, so I wanted to keep it to stock specs. 3mm is thinnest motorsport-tech.com would go. If you have stock length studs, you might want to invest in a little longer ARP studs.
Old Apr 12, 2015 | 08:36 PM
codyvette's Avatar
WOW! Thanks. I wish Moser would have been as helpful, but I guess then they would have to admit that part of their design sucks.
Old Apr 13, 2015 | 07:35 AM
ramairetransam's Avatar
ugh this makes me worried , i just installed my mwc this winter . Havent driven it yet . I think i have strange axles too .
Old Apr 13, 2015 | 08:26 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
The Strange axles we use have a long register now that centers the oem rotor and extends into the wheel properly. Most aftermarket wheels have a larger ID in that area and most likely will not fit true to the axle register like this.
Old Apr 13, 2015 | 08:50 AM
codyvette's Avatar
That is how my Race Star drag pack is built but they came with hub adapters. I realize it works out most of the time with the lugs but the hub centric design is way better IMO. It's good to know Strange made this change. I am sure it won't cause as much heartburn as it not being extended.
Old Apr 13, 2015 | 09:36 AM
good to hear , then ill be fine with my ws6 rims then .
So this was an issue with too short of a "register" on the axle ??
Old Apr 13, 2015 | 06:55 PM
_JB_'s Avatar
Yeah, the vibrations sucked and I complained about it as soon as I left MWC.
You can test your car without even driving it. Just lift the rear of the car (keep the suspension loaded), start it up, put it in gear, and let it run at idle. Watch the lip on your rims and see if wobbles.
This is how much hub my axles have; if you want to call it a hub lol.
Old Apr 13, 2015 | 09:44 PM
wow thats **** , mine is still doing a wheelie on jack stands for the fmic install . so i will soon get a pic and add to this thread.
Old Apr 14, 2015 | 05:15 AM
  #32
Orange Juice's Avatar
I get a shudder when the car goes down hill, just thought it was the 9in, I also battled the vibration in 5/6. The tranny shop swore that there was nothing wrong with the shaft and f#cked around with the car for way too long until I insisted that they replace the shaft. I've since quit doing fifth and sixth gear pulls.
Old Apr 14, 2015 | 08:32 AM
  #33
ssvert99's Avatar
JB your rearend was very early in production, and it has Moser axles in it. We had some issues and switched to Strange as soon as they made their axles long enough for the stock width f-body dimensions and have had little of no issues since.
Old Apr 14, 2015 | 07:26 PM
  #34
_JB_'s Avatar
Well as long as your hubs look better than that, you'll have a lot better chance of no vibrations.
  #35
_JB_'s Avatar
Sent you a PM.
Old Apr 16, 2015 | 05:05 PM
  #36
RedDeadG8's Avatar
when were the new Strange axles used? I bought my MWC 9" back in 2010
Old Apr 17, 2015 | 08:36 AM
  #37
MidwestChassis2's Avatar
In 2010 you would have received Strange axles.
Old Apr 26, 2015 | 09:03 PM
  #38
RockinWs6's Avatar
I want to add my experience with differential vibrations. I switched from a Torsen carrier to a Auburn carrier, instant drone vibration from THE CHEAP UNBALANCED Auburn carrier. Yanked it back out and put the torsen bk in....smooth as silk...........
Old Jun 30, 2015 | 12:32 PM
  #39
codyvette's Avatar
I am finally getting around to trying a fix for the short registers on my Moser 12 bolt axles. I am keeping my fingers crossed.
I am gonna weld up the center hole and possibly the outside. From what I gather, strange makes there registers longer now or maybe always have.
Old Jun 30, 2015 | 01:24 PM
  #40
how much are new axles since you already have the axles out ?
