are there any affordable rear ends for an f-body?
as the title says. the factory 10 bolt in my 2000 ws6 has seen better days
(front gasket went out and was screaming on the highway, took it to closest garage where they replaced the seal and said i should get a whole new rear as mine has play in it?)
so i was just wondering if there are any affordable 9" options, as in under 2k. Or if there is a good place to get used housings or if im just stuck saving all my pennies for the year 2018 when i can finally afford a 9"
The answer is no.... There are no affordable rearend swaps for a F-body. Just expensive ones unfortunately. Gm needs there *** kicked for putting that weak *** trash in those cars. IMO.
