Moser 9'' 31 spline axles how much hp?
In my case it wasnt the actual shaft that twisted, but the splines.
And oddly this only occurred after I upgraded.
I started with small diameter 28 spline shafts. These never gave any problems.
Then upgraded to large diameter shafts but still 28 spline ( larger c-clip elim bearings )
The splines twisted slightly
I then upgraded to 31 spline which used the same larger diameter shaft but with 31 spline. Again these splines twisted
Both times they twisted by about 1 full spline.
I'm now using Mark Williams shafts and have no such problems.
