Which gear oil
Old Sep 15, 2012 | 06:17 PM
NYTHAWK's Avatar
Default Which gear oil
From what I understand if you have a Gorden differential you don't need the limited slip additive. How do I know which diff I have? Do I need to use synthetic, or non synthetic? Which oil weight? I have an 02 Ws6.
Old Sep 15, 2012 | 08:41 PM
NYTHAWK's Avatar
Torsen, sorry.
Old Sep 15, 2012 | 09:38 PM
User Name Here's Avatar
The torsen has several gears in the diff unit that you can easily see. If you can't see gears in the diff unit you should use LSD additive. Or you can use it anyway - it won't hurt the Torsen from what I've read
Old Sep 15, 2012 | 09:47 PM
senicalj4579's Avatar
I just changed mine again after the 3.73 install with Lucas 85W-140. Its non synthetic. It says it already has an additive in it but who knows. I have a torsen also so I wouldnt need the additive anyway.
Old Oct 26, 2012 | 10:21 PM
exodus_gs1's Avatar
I have a 02 z28 with 4.11's, do I need the additive? I didn't do the gears bought the car with them and im about to do a girdle and want to make sure I use the best gear oil to get the most out of it
