9" question
Old Oct 3, 2012 | 05:13 PM
ThumpnZ28's Avatar
Smile 9" question
Who can give the the part # for the u joint needed to go from a 10 bolt to a 9"? Thanks all.
Old Oct 3, 2012 | 05:37 PM
ssvert99's Avatar
LS1Tech Premium Sponsor
Precision 447 should do the job
Old Oct 3, 2012 | 07:27 PM
ThumpnZ28's Avatar
Will the u joint straps still work, or do I need different ones?
Old Oct 3, 2012 | 07:36 PM
ssvert99's Avatar
figuring your 9" u-joint is a 1350 then no. the 1350 series uses a 3/8" u-bolt, the oem 10 bolt uses a strap with two 5/16 bolts.
Old Oct 3, 2012 | 11:38 PM
ThumpnZ28's Avatar
Can I buy both parts from you? PM me if you can.
