Help! Old rear out of car
If you are using the TCS/ABS wheels press those on first. Then the backing plate/caliper mount slide on, then the bearing (make sure the o-ring faces the outside), get pressed on, then the bearing retainer. The two small seals are installed in the rear end housing, I had a piece of pvc pipe thet fit the bore exactly and used that and a BFH/2x4 to put them in. they have to go in far enough so the bearing retainer doesnt hit them.
Make sure you get the correct side caliper mounts on the correct axle, one side is longer then the other so the axles do not interchange like a 12 bolt. There was a recent post on which axle was which - the RH side is the shorter axle if I remember but double check since the bearing will be destroyed if you have to take it off..
THX, Im hoping to get all this done on saturday....Not using abs so thats one less problem.What all did you have to take to a shop to have put on? or were you able to do it all with BFH.
S
S
