Narrowed or not narrowed 9"
from what ive seen 2-3 inches per side is the norm...lot of options in wheels and offsets...should be able to fit a 305 in the stock wheel well...
Someone with a narrow rear, please post up. I searched and searched and found nothing. Not even in the FAQ sticky. plz help.
MWC manufactures the most popular bolt-in fabricated 9" rearend package for the f-body cars and have the track and street experience to back it all up. MWC is also a direct dealer for Strange, Moser, and Yukon and have the guaranteed best deal on any rearend and suspension component for your car.
4.75 backspace, running a 315/35r17 MT street, no rubs, or cutting at all.
Dropped about an inch all around. Benefits......bad *** lips..... Drawbacks ....no spare tire will work lol!!
Can't feel any handling difference, feels the same, just a hell of a lot stronger than the 10 bolt.
I narrowed my S60 a total of 4.5'' the only draw back I have experienced is custom wheels you will have to wait for them to be made and usually there not cheap.
I guess you really want wider than you will have to mini tub it, Ive seen 335 with that setup
If you are trying to run a fatter tire but not have any clearance issue you can keep your stock width rear just change the backspacing of the wheel to push it out of the fender more. So say stock backspacing is 7.5 you want to run a 335 and need a extra 1/2'' clearance set your backspacing to 7.25 and it will push the wheel out towards the outside of the car making you have more inner clearance.
I did something similar with my narrowed rearend, I didn't like how my first set of narrowed TT2's sat in the wheel well (5.5'' backspacing) so I kept the length of the S60 the same (2.25 taken off each side) and ordered another set of TT2's with a 5'' backspacing so the wheel was pushed out more where and how I wanted it and gave me more room on the inside. Just be careful and not do it too much or it will look ridiculous.
This is how the wheels sit now at 5'' backspacing
