9 inch install issues... Sway bar dosnt fit!
Old 10-25-2012, 12:21 PM
jimmyducati's Avatar
Default 9 inch install issues... Sway bar dosnt fit!
I know about the sway bar mount not working from the stock 10 bolt, my issue is the swaybar makes contact with the torque arm mounts on the rear end before it is even close enough to the sway bar mounts on the bottom of the axle tube! Any suggestions?
Old 10-25-2012, 12:34 PM
Blackbird-WS6's Avatar
you may need a set of these to push/space the bar down, i have a 9inch with BMR sway bar with those brackets and dont have any problems
http://www.spohn.net/shop/1998-2002-...ation-Kit.html
Old 10-25-2012, 01:00 PM
That looks like it is what I need... Damn Im sick of shelling out money to get this 9 inch installed!
Old 10-25-2012, 01:02 PM
i told myself the same thing
Old 10-25-2012, 01:13 PM
I emailed them to see if i can get just the sway bar brackets without the end links... just bought them last week.
Old 10-25-2012, 01:15 PM
well you may need longer endlinks to put the sway bar back in alignment, use the ones you have now and when you put the car back on the ground look and see, if the angle is wrong then you need longer endlinks
Old 10-25-2012, 01:42 PM
The endlinks I bought were about 1.5 inches longer... I was going to reuse the sleeve from the old endlinks, but i still have the longer sleeve that came with them
Old 10-25-2012, 06:23 PM
trans_am7935's Avatar
just curious, are you gonna paint that rear end, looks bare to me.
Old 10-25-2012, 09:35 PM
its already painted... hi temp steel color from VHT
Old 10-25-2012, 09:49 PM
HoLLo's Avatar
Mine's the same way, except rubs on the other tube. Stock swaybar, poly end links. It's been like this for a year now. No noticeable issues with it, I just said screw it.
Old 10-26-2012, 09:32 AM
Im just kinda disapointed in how NOT "bolt in" the whole 9 inch was... even though it was advertised as a complete drop in event. Grinding on the expensive *** strange 3rd member to clear the torque arm mount, brake lines, sway bar issues, drive shaft issues.... way more than the 2500 budget i had
this thing better cook me breakfast when im done with it.
Old 10-26-2012, 12:59 PM
I didnt have any problems nor does my sway bar hit
Old 10-29-2012, 04:03 AM
BlackLS1Bird's Avatar
Mine was hitting too. I have the BMR Extreme sway bar. I just took a grinder and clearanced the torque arm mount. It is thick and the bolts only go about half way through anyways. You will not effect strength or durability in any way.
Old 10-30-2012, 12:37 PM
Grifter's Avatar
Same happened with mine but honestly that is a very minor detail in my opinion. A little grinding or spacers and it'll be fine.
Quick Reply: 9 inch install issues... Sway bar dosnt fit!
