S60 with S-Trac vs. 9" with True-Trac ?
i've got the relocation brackets welded on my 10 bolt....i'll make sure to add them to the S60.....but the actual LCA's themselves, do they need to be adjustable with this new rearend, or can i just grab a solid set like these
http://www.ws6project.com/user_stor/...-control-arms/
also, i was thinking about going 3 channel and keeping my abs, but deleting traction control....do you miss yours?......if i go this route, will the ASR light be staring me in the face the entire time.....i don't want dash lights
Order your S60 with the BMR lca relocation bracket option. Strange only charges retail cost of the brackets, no charge to weld them on. Adjustable lcas are not necessary for the S60 to center up in the wheel well. I measured where my wheels sat in the wells before and after the S60 install and the wheels ended up in the same spot. Car is standard height and 10 bolt with stock lca brackets vs S60 with relocation brackets, lcas installed in lower holes. Strange must have very accurate assembly fixtures they set these rears up in for welding.
I did do the 'hose mod' to the rear springs so the body wouldn't be raised by the S60 having larger diameter axle tubes which in turn raises where the spring perches sit. With the hose mod my rear ended up at stock height after the heater hose on the spring took a set.
I have non-adjustable LCAs with my S60. No problem. I ran it at the track last week and spun 1st and 2nd on the 1st run (need a line lock) and it stay perfectly straight. Other runs hooked and were straight as well.
Also, I ordered mine with relocation brackets welded on.
