which rear end on a budget?
Old Jan 24, 2013 | 02:57 AM
SSkippin's Avatar
Default which rear end on a budget?
is the 8.8 rear pretty much status quo for building a low budget fbody? How much abuse can the stock z rear take before exploding? iron headed non stroked small block, right much nitrous, th350 with NO tbrake...the 8.8 is tired and i have a stock z rear lying around. Will it hold up for a season?
Old Jan 24, 2013 | 03:12 AM
lemons12's Avatar
You talking about the 10 bolt? It holds up pretty decent in the 1.6 or slower range, anything faster and it could go any second. I wouldn't trust it on anything getting down decent in the 60'.
https://ls1tech.com/forums/parts-cla...-30-spool.html
Budget^
Old Jan 24, 2013 | 06:30 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
http://shop.brutespeed.com/Moser-9-I...-and-Axles.htm
A good low cost way to go that bolts right in is to use the above Moser 9 inch housing and axle package. Pick up a used Ford 9 inch center section and install it, and run it this way until you can afford to put a stronger aftermarket center section in it. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jan 24, 2013 | 08:15 AM
SSkippin's Avatar
Thank you, guys. I appreciate the help.
Old Jan 24, 2013 | 09:25 AM
01ssreda4's Avatar
Stock Ford center/posi aint no stronger then a 10 bolt. Hold out for something nice to go in there. The axle housing package is one of the better budget options to start with though.
Old Jan 24, 2013 | 11:07 AM
Guitar's Avatar
An 8.8 with some money into it can go far. If you want something bullet proof, go with a 9".
Old Jan 24, 2013 | 06:49 PM
Blackpanther99's Avatar
Agreed^
