Motive 3.55 gears installed
A slight whine on decel, but other then that all seems good. Short 25" nt01 tire required less gear then 3.73 to keep from up shifting to 5th on long track. Stronger gear, less spinning out of tight corners, although the 416 does not have the grunt out of corners as the old 468 bbc in the 67 camaro, I think it runs very similar lap times, making up in the twisties with the 02.
