Rear end popping sound? Help!
When going at low speeds (up to about 10-15 mph) I can hear a popping sound coming from the rear end of my 02 SS (stock rear end). It's related to the speed I'm going...the faster I go, the faster the pop pop pop popping sound is, up until about 15 mph or so, anyways. I can't tell exactly where it's coming from, however, I can tell you it has nothing to do with turning/going straight. It just seems to happen when I'm puttering around, less than 15 mph. If the sound exists at higher speeds, I can't hear it for the rest of the noise.
So my question is this - this weekend I plan on jacking my car up and crawling underneath to see what I can find. Do you guys have any suggestions on where to start? I don't think it's the u-joint, as it doesn't clunk when going from drive to reverse (but I'll check it regardless). Suggestions?!?
