Can bad pinion bearing cause a rearend vibration?
Here we are chasing vibes yet once again. I really dont think its T56 tranny related this time, feels like driveline.
I am replacing both u-joints tonight since one is not a genuine spicer although I am not encouraged it would help. The aluminum DS has not lost any weights and looks fine.
So I am wondering, could bad pinion bearings cause a vibe around 75MPH+ ?
A while back, my pinion preload was far too light and was making a strange noise when cruising at higher speeds when transitioning just on the gas and off the gas. Tightening this up help ed a good bit but the bearings were likely loose for a very long time.
Upon inspecting them, I did not see any obvious issues but in fairness, I dont know what to look for. Also I dont have any pinion whine or weird sounds like that. Vibe occurs on the road and on jackstands.
So can bad pinion bearings cause a rearend vibe?
I am really hoping that there is some funky wear in the bearings due to insufficiant preload that is causing this.
FWIW -
I get my Aluminum 3" driveshaft balanced once a year - when it bends (and it does bend, unlike steel, which just 'flexes' and then returns to its original shape) that bending causes my driveline to vibrate.
Just my $0.02...
Just my $0.02...
Update.
After closer eval of one of the u-joints, I now suspect wear. I also noticed that with the rear wheels off the ground, when you forcefully turn the rear wheels back and forth, I hear a what I would consider abnormal metallic clunking sound.
The suspect u-joint in question was actually installed last winter but it was not a Spicer part. It was a likely cheap Chinese **** part from the a discount parts house that I was forced to get because it was a Saturday and the Spicer shop was closed till Monday.
So after installing the new joint and rocking the wheel back and forth, that loud metallic clunk was greatly less obvious. I also while still on jackstands, I ran it up to 80MPH and the vibe was also significantly less than before. There is a very faint vibe still there at high MPH but I doubt it is of much concern and may even be considered normal.
I did not get to drive it yet because its been raining like Hell so it will wait till tomorrow. That said, I am very optimistic the issue is fixed. So the moral of this story is, only use Spicer u-joints.
i also have bad vibrations from the rear. i think it got worse since i installed a UMI tunnel mount tq arm. there is a metalic clunk noise when i let the clutch a little quick. im gonna start looking into this i guess today. any recommended u-joints if it is one? im about to do a search
