Has anyone ever bent a output shaft due to driveshaft failure?
I had my drive shaft have a critical speed failure, and it broke my tail housing off my trans (67 camaro, no torque arm) the shaft was defintly the start of the failure but I dont know if my trans will be hurt more than just a tail housing. Has anyone heard of more damage? looking on the forums I cant find any mention of it, but anything is possible.
![](http://i15.photobucket.com/albums/a380/mattc6/FB_IMG_13703821272024074_zps6a941714.jpg)
T56? If it is I would suspect it. Tear down to the point that you can spin the main/ output shaft. It is supported at the end of the main case. You might even start it up long enough just to look at it. But I'm sure a dial indicator would be more appropriate and turn.
