2.73s in an M6 LS1...
on a side not, have 3.90 Motive gears ordered and shipped. are these pretty good gears? I know if they whine from the get go, the pinion depth wasn't set correctly. if that occurs, i will have the shop get back in there and fix it. im not paying 500 dollars in labor to have **** half-@$$'d.
I know the STOCK gear ratio for T56 f bodies was 3.42, but as I explained, this had an aftermarket 2.73 ratio in it, at least this is what I was told. I also was told the bearings are all fine, they must have been replaced when these gears were installed.
I am now going with Motive 3.90 gears. I would like to know what I can look forward to in top end with these gears, as I wouldnt mind being able to pull some top end on the highway.
