LPW rear girdle install
So I'm going to be installing a LPW rear-end girdle today and have a couple questions before I do this. Yesterday I had jacked my car up to paint rear calipers and noticed two brackets bolted under the rear cover mounting bolts. So I dug out my installuniversity guide and saw his TA girdle came with two longer bolts for that spot. Checked my bolts and they are all the same length. What should I do to fix this? Just put in all 10 of the bolts supplied and hope they're long enough?
Well, as I suspected they were too short. So know I have to wait till Monday when Fastenal is open to get my extra 2 bolts. I've got all the bolts torqued on so after this I should be ready to go.
Before I go and buy any bigger bolts, (which will be like 2 days because online it says my local fastenal doesn't have them) does anyone know if I can just wire-tie the e-brake tubes to the axle tubes? They're wire-tied to the panhard rod so does it really matter?
