Strange 12 bolt rear end
LS1Tech Sponsor
http://shop.brutespeed.com/82-02-F-B...Ends_c2289.htm
Brute Speed is having a 10% off sale on all Moser Engineering items, starting November 25th through December 3rd! This includes 10% off complete rear ends!
Place your order on our website and I'll go in and immediately refund you the 10%
Thanks! Bob
Thanks! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
Realistically, the 12 bolt isn't THAT much heavier than a 10 bolt. Especially when compared to the weight difference with a 9" or S60. And even though you can get the noises from them from hard launches, they are primo for auto-x and road course use and even roll races on the highway, which is what the OP is shooting for. They do not eat up as much power as some of the other rears, they are relatively inexpensive, and parts are available almost anywhere. Throw a smooth running wavetrac in it and go. If you want to keep the weight down even further since the wavetrac takes 35 spline axles, get an Eaton with 33 spline and call it a day.
12 bolt rears are known to pick up noise with a few hard launches. If you were an A4 car then maybe, but you need to consider the fact the S60 rearend is much stronger and a bit less cost even. If you are dead set on a 12 bolt then the Strange rearend is the only way to go.
I can get you into a lightweight fabricated 9" rearend complete package that includes a chromoly adjustable torque arm, crossmember, Strange axles, Strange aluminum center section with a posi unit for about 3300.00 shipped. By the time you add the cost of a good torque arm to the 12 bolt you will be very close to the same cost.
LS1Tech Sponsor
The factory aluminum driveshafts are paper thin, when they break they normally take out other parts as the front part of it continues to widely swing around under there. Bob
__________________
That's true, they generally dent the floor pan and destroy the parking brake cables that run in the tunnel. There are also fuel and brake lines that can be damaged. Worse case scenario they tear the transmission up. Just not worth it to push a stock driveshaft.
My torque arm has a driveshaft loop , I don't dump the clutch , I do rolling starts , I don't drag race , so there should be no problems .
LS1Tech Sponsor
Most F Bodys came from the factory with an aluminum driveshaft, and many people break them when power shifting into second, so be careful. Bob
__________________
LS1Tech Premium Sponsor
One of my fabricators here broke the stock shaft with the 10 bolt in the car still- on the street, and on factory tires.
The real scenario is if you plan on any performance driving whatsoever that the stock shaft will most likley be comprimised at some point. If you break the stock shaft, it tears up the floors, exhaust, and usually the trans too, you will easily incur 1500.00+ in repairs... then you still have to buy a driveshaft to replace the failed one!
Take the 150.00ish you can get out of selling your factory shaft and apply that toward a good one that won't cost you 1000s in damage. Your end result is only about 150-300 out of pocket then.
Give us a call. We are direct with Strange and PST and offer the lowest prices on several choices of driveshaft and yoke stlyes. We will also be glad to help you on selecting the proper rearend when you decide on that as well. MWC is the leader in f-body rearends! Guaranteed lowest prices, expert tech help, best service. Give us a call or email for any info you need!
#32
LS1Tech Sponsor
No matter who/where you buy a driveshaft from, I would get an aftermarket one to replace your factory driveshaft. Bob
__________________
#34
Got the S60 in my 6spd car...right now im at 465/427 at the tires...i got it with a Truetrac diff so I could still drive and enjoy my car and its great. Wouldnt ever know its back there. Awesome rearend. I plan on adding a procharger down the road soon...however even if i wasnt, the S60 would still be my choice. 12 bolts are known to lack pinion support and are not suggested for manual tranny cars.
