Driveshaft slip yoke ???
The engagement into the transmission should be from 2 3/4 to 3 inch max. The part remaining outside should be 1 inch.
Use some permanent marker or some paint marker to highlight how much engagement you have. You can get away with 2 inch as a temporary setup like reusing the stock ds but its not recommended.
