Balancing a driveshaft
Many companies with older balancers are limited to 2000RPM, most performance driveshaft companies have balancers approaching 10,000 RPM.
Carl
for an automatic transmission 4th gear ratio is 0.7 to 1 so 2000/0.7 = 2857 drive shaft rpm.
my guess is your drive shaft shop doesn't do enough business so they have a cheap balancer that only does up to 2000 rpm. but the way you described what was told to you they are either lying to you to get your business or they are incompetent. nearly every car has an over drive transmission, and over drive by definition means a gear ratio less than 1 which means the drive shaft will always spin faster than the engine. for them to say it never does is a big red flag.
and like said there is no reason or need to balance a drive shaft after doing u-joints.
what you should do is mark which way the transmission yoke goes on to the drive shaft and reinstall the same way, they are typically balanced with the drive shaft so if you install it 180° out there is the slight possibility the shaft + slip yoke might be slightly out of balance.
I seriously doubt any shop with an old style, low speed balancer would be able to either.
