Another differential question
Old Feb 23, 2014 | 04:31 PM
Bad28's Avatar
Default Another differential question
Ok so when I upgrade my h/c/I I will need to do gears now I don't have the money to just order a new one from strange or moser and was going to just install 4:10s into my 10 bolt I have heard that 4:11s may be better can anyone post up a link to something explaining what's better and why and the advantages of each
Old Feb 23, 2014 | 05:02 PM
BIGsmokey10's Avatar
Are you asking the difference between a 4.10 and 4.11 gear ratio. Not a whole lot lol.
Old Feb 23, 2014 | 05:06 PM
BKsNHRA's Avatar
I dident think they offered 4.11. 4.10s will work but if you got a sticky tire/drag radial on your car its not gonna last. I broke 2 sets of 3.73 and now something else is broke within the last 6 months. Im not even gonna open it up this times its gonna sit until my new strange rear shows up. If you have 3.42s that's what id leave in it until your ready to upgrade. Don't waist money like myself and others have done. If your dead set on changing gears I wouldent go much steeper than a 3.73. After 3.73 it seems the rears just are not reliable at all if your gonna be beating on it.
Old Feb 23, 2014 | 06:43 PM
Bad28's Avatar
That was my thought but someone had told me that the teeth on the gears were bigger and thicker on the 4:11 I didn't see how it was possible or if it was true
Old Feb 23, 2014 | 06:55 PM
guppymech's Avatar
If your car is a M6 putting 4.10s in the 10 bolt is a waste of money. I know because I did it and have a 4.10 10 bolt laying in the garage with nice and quiet gears with a worn out posi unit. You'll have less traction and won't be able to put DRs or a good bias ply tire on it for the track for fear of blowing up the rear. All the HP you will add with the h/c/i won't do you any good if you can't hook it up. Why not build the car the strong way from the rear forward, then you'll have no worries.
As to your question, when you order 4.10s you get 10/41 gears, sometimes I've heard of a couple people getting 4.11s 9/37 gears as a substitute for 4.10s. I don't think anyone actually sells the 9/37 gears even though they advertise them as 4.11s. They're all 4.10s when dealing with the 7.5/7.625 10 bolt.
Old Feb 23, 2014 | 07:16 PM
Bad28's Avatar
That's what I had heard just didn't know if there was any truth to it I think I'm just gonna have a friend of mine weld up an explorer rear end
Old Feb 24, 2014 | 10:54 AM
01ssreda4's Avatar
Actually, your friend is correct. However, not all gear ratios are made for all rear ends. And I don't think 4.11s are available for our ten bolt.
Old Feb 24, 2014 | 12:20 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
here's a link to a Richmond PDF showing what's available for what vehicles.
http://www.richmondgear.com/pdf/Rich...n1.pdf#page=22
Old Feb 25, 2014 | 01:43 PM
Jr.Samples's Avatar
I think the 4.10 is just about right for a M6 street car. Unless you are playing John Force with slicks or something it will work real good.
Am I living on borrowed time? Maybe. 164,200 flogged miles and counting.
