Moser Press-ring size differences
Recently picked up a 12 bolt (big Ford ends) set up for 3 channel ABS. I needed 4 channel ABS, so I ordered the reluctor rings and new bearings/press rings from Moser.
The original press rings are 3/8" wide, and the new ones are 5/8" wide. Once the new rings are installed, they WILL make contact with the inner axle seals, so much so that they will cause the axle and bearing to stick out 1/8".
Not wanting to run without an inner axle seal, even though they are sealed bearings with outer o-ring, I picked up NAPA 15142 rear axle seals, and while thinner than the Moser seals, still not thin enough for proper clearance. I ended up installing them backwards which gave me plenty of clearance and should seal well enough.
After speaking with Moser, they have seen this problem before. They originally switched from the 3/8" to 5/8" press rings because some of the circle track guys had axles walking out from all the go-fast-turn-left. He said they're in the process of going back down to 1/2" I believe, which combined with the thinner NAPA seals, should give enough clearance.
Just a heads up, if you order new bearings and press rings, make sure to ask for the thinner press rings. If mine start leaking, that's what Im going to do, but for now Im betting what I did is going to work fine.
Did you have noticeable interference when tapping the axle in? I just finished up my QP 9" and didn't think to pay attention to the rings/seals interface. The axles went in fully with the inner seals in place without any undue hammering. This is the only pic I have of the axle end and one of a few of the flange. I did measure to make a spacer for the Explorer brake swap and didn't see any clearance issues with measurements...
Thanks!
