Rear Diff - What is this?
The center block(commonly reffered to as a 'paddle') pulls out and since the bolt/screw is already removed,the paddle should just pull out. In picture 3,there seems to be some sort of 'shim stock' sticking out. What is that ?
The Torsen carrier in picture,because of its' short cap(the 6 bolts on the left side)appears to be a 2 series carrier used for 2.73 and 3.08 gearsets. If the gears have been changed to 4.10s',the paddle might have been had to be forced/hammered in resulting in great difficulty removing it. Get the ratio off of the ring gear,2 numbers indicating number of pinion teeth and number of ring gear teeth.
Once the paddle is out,the axles are pushed in to remove the c-clips and then the axles pull out. The carrier then come out in the normal fashion.
and there were some hack ways around it, maybe it was fitting it using the series 2 carrier. pretty sure it was somewhere on here i heard it, i basically remember you can't go higher than the 4.10 gear set in the 10-bolt because they don't fit.
Torsen T-2 diff specs
