3.42 gear
Old May 16, 2004 | 03:53 PM
indy500's Avatar
Default 3.42 gear
what do you think guys a bout this combo. (( 3.42 gear +3200 stall )) in c5 ?
is it worth to swap 3.42 from 3.15 ?
what is the top speed with 3.42 gear ?
Old May 16, 2004 | 10:33 PM
kp's Avatar
kp
I had a 3.15 in my C5 with a vig 3200 and it worked just fine for waht I wanted. I wouldnt go through the trouble unless you can pick up a 3.42 diff cheap or you are going for that last 10th at the dragstrip. Its only a few bolts to change it once the trans is out so thats the time to do it...
