Question about rear end install?
IMHO, if he knows how to check and set up gears, I'd pay 200 for him to crack the cover and make sure the depth and backlash are all correct. Moser's gear setup can be very hit or miss. This is why you see alot of people complaining about excessive whining. If the gears are set up correctly by someone who knows what they are doing, then they should be fairly quiet. So to me, the extra 200 is worth it, unless you don't mind having your rear sign the high notes with Freddie Mercury.
if the rearend is brand new ZERO miles I'd say its worth letting him go into it so that it'll be warrantied. If its a used rearend then no, because the gear will have its pattern worn into it and its too late to make it quiet.
i agree with moser being hit or miss on their setups.
Do you guys not have private installers in your area? i do clutch, slave and master for $150. and install a rear end for $100. but i don't have the right equipment to check the gears.Theres plenty of guys like me here in texas but i guess not alot in your states huh?
