rearend
Old Aug 15, 2014 | 02:34 PM
southernlsx's Avatar
Default rearend
Does any body no what this g12b373 gear set is fits a 1 bolt chevy
Old Aug 15, 2014 | 04:44 PM
01ssreda4's Avatar
Looks like a standard 3.73 3 series gearset. Google didnt turn up anything with that part number.
Old Aug 16, 2014 | 06:45 PM
No I googled it didn't bring up nothing think its a stock gm gear
Old Aug 16, 2014 | 08:00 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
measuring the diameter (largest dimension tooth to tooth) will tell it application.
7.5",8.2",8.5",8.9".
Old Aug 17, 2014 | 05:22 PM
That will tell What kind it is
Old Aug 17, 2014 | 07:21 PM
If it's GM or for a GM
7.5" and 7.625" is for the little 10 bolt
8.2" is for a GM 10 bolt
8.5" and 8.625" is for a GM 10 bolt
8.9"(8 7/8") is for a GM 12 bolt
there are others smaller and larger than the above listed range.
Old Aug 21, 2014 | 12:27 AM
Got my new gears in the other ones was a stock gm 373 went with a set of motive 373 gears so much quiter and a lot stronger thanks for the help guys
