3.73's or 4.10's
3.73's or 4.10's
combo
heads/cam peaks @ 6300 but carries flat till 6600+
tci 3500 converter but will restall in the future for 4000+
basically with all the calculators i should be ok shifting @ 6600 without hitting 4th gear but you know how racing calcs can be so i need some advice...personally I'd rather go with the 4.10's. I run 26X9.5X16 hoosier QTP's. IM probably not gonna be able to lay down trap speeds of more than 115 for a while so whats that like 117 exit or so? Hopefully i can get some help.
Thanks
Bill
Thanks
Bill
4.10's will get you 6200ish at 117. sounds perfect for what your doing..
btw. did i read this right? 2.73's? my god, are you going to love 4.10's
with that said, 3.73's might be better if you do a lot of freeway travel.
but, you would be giving up about 500 rpm's in the traps
what is more important to you
I just ordered a set of 4.10s for my car from New Era,they have a great GP right now for OEM gears and install kit,$200.I will try them in my 10 bolt and hope it still holds.
I have a Moser 12 bolt in my garage with 3.73s,when it goes in I can get a good 3.73 to 4.10 comparo.
im actually gonna try and get my hands on a set of 4.10 2 series gears, I just bought an extra 2 series posi on the cheap and am just gonna go that route...i hear the 2 series are thicker & ive got an auto w/ girdle & stud kit out back so i just hope it holds together.
