GEAR advice !!
Old May 25, 2004 | 02:29 PM
10SECWS6's Avatar
Default GEAR advice !!
ok , i'm running a 26 tall et drag tire, i shift my car at 6,400 rpms, on nitrous would i make it through the traps in 4th gear with 4.10s? or can someone tell me what would be the best gear to go with , i have a full weight t/a making 600hp rwhp .
Old May 25, 2004 | 05:35 PM
Tranzor's Avatar
Yes you will most definitely make it through the traps if you're shifting at 6400 rpms... If you're redline is at 6400, that would be around 121mph at the end of 4th. So unless you're trapping higher than that, I wouldn't worry about it. If you are trapping higher, you need a taller tire (like say 28") and/or increase shift points a couple hundred rpms.
Old May 25, 2004 | 06:24 PM
SUX2BU's Avatar
youir gonna need 4.10's and 28" slicks thats what i use and i have a 424RWHP car with a 150 wet shot. M6 full weight
Old May 25, 2004 | 06:26 PM
SUX2BU's Avatar
you can trap up to 134 with 28's
http://www.woodyg.com/fairlane/finfo/mph.html
Old May 27, 2004 | 01:48 PM
10SECWS6's Avatar
i just ran the car on a 17inch drag radial and it did 11:50 @134 mph, how fast can i go with a 26 tall tire with 3.73 gears ?
