clunking noise
Old Nov 9, 2014 | 10:55 AM
slt200mph's Avatar
Default clunking noise
When the cars is turning the rear end makes a clunking noise it does not do it if you push in the clutch and coast through the turn. Before it started making the clunking noise it made a growning noise while turning. The growning noise then turned into the clunking noise. I am thinking that the posi traction is worn out. Can it be rebuilt or do I need a new unit.
Old Nov 9, 2014 | 12:03 PM
VandykeT/A's Avatar
If it's a auburn you can replace the axle gears. Mine did the same thing. Axle gear was broken. If it's a Torsen id just find a carrier.
Old Nov 9, 2014 | 12:42 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
A Y2K(2000) would have a Torsen. 98s' and earlier had Auburn.
Old Nov 15, 2014 | 02:42 AM
LS1nut346's Avatar
It doesn't sound like the problem is in your rear if it stops when you push in the clutch.
Old Nov 15, 2014 | 08:34 AM
slt200mph's Avatar
No sir you are incorrect posi was trashed
Old Nov 17, 2014 | 08:03 AM
LS1nut346's Avatar
Interesting. Well it's tough diagnosing noises over the net.
Old Nov 17, 2014 | 04:22 PM
slt200mph's Avatar
Not if you understand how a posi unit works
Old Nov 18, 2014 | 06:28 AM
LS1nut346's Avatar
You're the one on here looking for help. If you're such a genius, why post in the first place.
Old Nov 18, 2014 | 08:00 AM
slt200mph's Avatar
You ran your pie hole about something you nothing about. Your comment proved that. I fixed it and it was what I thought it was to begin with. Anytime you need help trying understand how something works feel free to ask. I'll be happy to teach you. Have a nice day
