How to change rear axle fluid?
I did some searching and couldn't really find a walkthrough on this. Perhaps it is really simple, but could someone give me a brief guide to doing this, including how much fluid and what kind of fluid I need to do this.
Thanks
Thanks
To change the fluid in the stock rear end with stock rear diff. cover, you have to remove the diff. cover and let all the fluid spill out. Then put the cover back on and fill it up using the fill hole on the passenger side of the diff. housing. Should take about 1.75-1.9 quarts of gear oil. Just pour it in until it starts running out of the fill hole, then you know its full.
For fluid, I like Redline 75W-90 gear oil (no limited slip additive needed with this fluid), but the choices are many.
Originally Posted by elderon
Sounds pretty straight forward. Is there anything I need to know about taking the cover off? Just loosen the bolts with a wrench? Any idea what size they are?
